Sponsored by: CARiD
Cleaning the MAF
Old Apr 17, 2007 | 02:40 PM
5301113's Avatar
Default Cleaning the MAF
I saw on a show that you can clean your MAF (the little metal sensor in the MAF) with brake cleaner. Is that safe? It's a small maintenance that helps the MAF read correctly. Sometimes dirt and oil from the filter cause it not work right.Has anyone ever heard of this? Is is true or will it hurt the car more the help????
Old Apr 17, 2007 | 02:46 PM
staringback05's Avatar
you have to be careful using sprays, those electrodes are very fragile
Old Apr 17, 2007 | 02:54 PM
2001NBMZ28's Avatar
Don't know about brake cleaner? Don't they sell MAF cleaner spray off the shelf? Thinking I saw it at Pep Boys.
Old Apr 17, 2007 | 03:04 PM
im pretty sure they do
Old Apr 17, 2007 | 04:01 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Never used brake cleaner myself, I'd be afraid to use that stuff for something so delicate.
Rubbing alcohol works well though.
Old Apr 17, 2007 | 06:04 PM
taintedmeat's Avatar
I use CRC Electronics cleaner. They also have a special Maf cleaner spray now.
Old Apr 17, 2007 | 06:10 PM
Da Swami's Avatar
I used the "special" CRC MAF Cleaner in the gray bottle.
It worked awesome and I TRULY saw an improvement in idle and gas mileage. Mine had 112k on it.
Old Apr 17, 2007 | 06:16 PM
Demon_Speeding's Avatar
I've used rubbing alcohol and a Q-Tip very carefully with good results. Worked on my '86 IROC, my Z28 and a buddies '87 Grand National.
brad8266's Avatar
Any auto parts store sells MAF cleaner in a spray bottle. CRC makes it.
Old Apr 17, 2007 | 08:42 PM
Formula413's Avatar
+1 for the CRC MAF cleaner, I have read that Brake clean or Carb cleaner are too harsh. For what a MAF sensor costs it's worth it to get the right stuff.
Old Apr 17, 2007 | 11:13 PM
CULATR's Avatar
where do i get a can of it at ? auto zone, advance auto, etc........??
Old Apr 18, 2007 | 02:50 PM
LS1Formula01's Avatar
yes just about any local auto parts store should carry it, costs about $7 bucks/can to keep your well over $100 (replacement cost) MAF clean!
Old Apr 18, 2007 | 10:59 PM
CULATR's Avatar
Found it today thanks !!!
Old Apr 19, 2007 | 12:12 AM
+1 for the alcohol... that works on everything...
Old May 16, 2007 | 01:50 PM
LS1Aggie09's Avatar
mmmm alcohol
Old May 16, 2007 | 03:59 PM
5301113's Avatar
Originally Posted by LS1Aggie09
mmmm alcohol
+ 2
