diagnose my squeek/grind..
Whenever im making a right turn.. the faster im going and harder i turn the louder it gets, i know its coming from the back left of the car and it sounds almost like brake squeal but i know its not... I just changed pads a couple months ago and it happened a couple weeks after that but it doesnt squeek when im braking normally however it im turning right and braking, its worse its louder than normal..
Couple it possibly be the caliper? Im hoping its not related to the rear end because i dont have that kind of money now and its definately coming from the wheel well area..
Originally Posted by carado1984
is that a PITA to fix.. expensive?
That being said, I've never tried myself to sliderhammer out one of the bearings so I'm not really sure how good they're in there.
but wouldnt the bearing then be almost in the housing of the rear not towards the wheel?? it distinctively sounds like its coming from the wheel?.. i think ill take the wheel and caliper off is there anything i should look for that could cause it out there.. maybe something needs greased?
