Clicking noise from front right wheel
Whenever I hit a speed bump or any dip in the road, or even sometimes when I turn the wheel, I get a single click that sounds like metal hitting metal from the front right wheel. At first I thought it may have been the shock but then it started doing it when I would turn. I also checked the control arm bushings and they seem to be in good shape. Any ideas?
not yet but damn i hope its not them, i hope i dont have to pay someone to press balljoints! someone suggested my u joints too so when im up under there putting on the new rear diff pinion seal ill give that a shot.
has no one ever had this problem?
Copy & Paste Moderator
Check out this FAQ in the Suspension & Brakes section:
https://ls1tech.com/forums/suspension-brakes/696182-general-suspension-issues-questions-faq.html
I chased a click like yours for a long time, it ended up being the nut on the top of the shock. I had to take the shock and spring out, compress the spring and tighten the nut to make it stop.
