Sponsored by: CARiD
coolant light on?
Old May 1, 2007 | 02:42 PM
MidwayAvenue's Avatar
Default coolant light on?
my coolant lights been comming on only when driving for a while...i checked the radiator and its full..what else should i check?
anyways any help appreciated thanks
Old May 1, 2007 | 02:52 PM
2001NBMZ28's Avatar
Probably the low coolant sensor in the radiator went south. You can replace it, try cleaning it, or since you have an actual working gauge disconnect it to keep the light off.
Old May 1, 2007 | 03:58 PM
SStheBest's Avatar
Old May 1, 2007 | 03:59 PM
Kage's Avatar
Cool
Originally Posted by 2001NBMZ28
Probably the low coolant sensor in the radiator went south. You can replace it, try cleaning it.
x2
Old Aug 27, 2007 | 04:23 PM
wheres the low coolant sensor located thanks
Old Aug 27, 2007 | 04:37 PM
2001NBMZ28's Avatar
On the radiator a few inches below the cap. Can't miss it, look for the wiring connector.
Old Aug 27, 2007 | 06:55 PM
yeah i found it right after i posted
thanks
