Coolant Pressure Test Help
P.S. Why are you performing this test? Overheating? Leaking? Coolant dissapearing?
http://www.blockchek.com/kits.htm
Or make sure your adapter looks like this one.
Scroll down to page 4 and look at MV103. This is the MityVac brand adapter for our cars, but any other brand will do as long as it looks like this.
http://www.mityvac.com/catalog/Adapt...tion_Guide.pdf
The following is part four in a series of excellent articles detailing a stroker build.
I've quoted a few lines that may or may not interest you.
Check it out.
http://www.gmhightechperformance.com..._engine_build/
"For example, coolant entering the crankcase will usually cause the oil to appear milky. The LS1 engine is known to occasionally have this happen when equipped with an MLS-style head gasket, but these leak issues usually only occur when the block or cylinder head deck is not properly prepped. "
and
"As soon as the coolant reaches full temperature (indicating that the thermostat has opened), turn the engine off and let it cool to the point where you can open the radiator cap. Top off the coolant as needed; this may need to be done a few times."
Did you do this?
