Help! car is stranded at autozone
Last night i changed spark plugs and broke my coolant temparature switch doing so. Drove the car to auto zone this morning and had them try to sell me a "temp gauge sending unit", try to install it. didn't work obviously. So i reinstall my broke one with plans to try the next parts store, forget to plug in the plastic connector, attempt to start it with no luck. The motor cranks but no fire. I realized at the time that i forgot to plug it in so i do so, and still no fire.
Could the coolant that dripped out of the block got something wet and shorted something out?
or something else?
help please!!
'98 use a different temp sensor than '99+. I wonder if maybe autozone only carries the sensor for the newer LS1s? Either way, I know you can get the part from the dealer, but this might not be an "in stock" item.
As for why it won't start, not sure on that one. Was the car giving you any issues the last time it ran?
EDIT: The 98 sensor is 3 pin, not 2 like I said. They 99's are 2 pin.
yup he is correct...im willing to bet the same thing....you might wanna pick up a set of plugs also because they probably are gas soaked and fouled.
I couldn't find your post in the part number thread, but here is the '98 sensor GM part number that I have in my records:
12551708
Is that the same number you've posted in the past? Not sure why I can't find your post....search must not like me today.
EDIT: I'd go to gmpartsdirect.com and get it from them and get it shipped faster, you don't want any auto parts store to order it and get the wrong one.
