air conditioning question
The O rings between lines are usually where most leaks occur. Take it to a pro for diagnostics and fix or get a cheap leak detector set from an auto parts store, find the leak if possible, fix it yourself and take it to get a vacuum pulled and professional recharge or take it to a pro after finding the leak and tell him what you want done vs. paying for the diagnostics.
On a side note, replacing the reciever/dryer isn't required but is a good idea and either way you look at it your gonna have to pay.
i took the belt off my ac...and i also live in florida
Mine are off in Hot Texas. Moving to Maintenance.
i have found that if i use the AC enough it wolnt leak, but once it goes a few weeks without the ac being used it will all leak out.
so basically i have to recharge mine every summer, but its not a huge deal
