car won't start and everything is going wrong
Allright I changed the clutch on my car this weekend. We ended up not being able to get the hydraulics to firm in in the pedal. We took it for a spin and right back cranked up fine and everything. Got back still bad pressure so we took the master out and bleed it.
here's the problem
The next morning I take it out of the garage to drive to the shop cause I was done with foolin around with it. The car won't crank. just ticking.... we back it out and try and charge the battery and there's no spark from the battery. But somehow after much clicking the car turns over after I play witht he clutch pedal finding the right spot. After the gauges were flickering and crazy **** on the dash board was going on.
I get it half way down the street and the car just dies, all power gone. We weren't able to get it started again and towed to the shop. We have charged the battery and still get nothing but ticking. The car will charge up to around 13 then when try and start it it falls on its *** and dies.
I have no idea what to do to get it running, it's at the shop right now.
PLEASE HELP ME
here's the problem
PLEASE HELP ME
The battery may have 13 volts fully charged. It probably doesn't have good enough cranking amps to turn the engine over. Bring your battery to a parts store and have it checked. Or, get a volt meter and have somebody turn the key while you look at the voltage drop at th battery. Look on the battery for the right CA level
