Sponsored by: CARiD
2001 Trans Am Headlights Question
Old May 10, 2007 | 05:55 PM
Charlie Hustle's Avatar
Default 2001 Trans Am Headlights Question
I havent been able to find anyone else on here with the same problem. Every time I turn the headlights on, they will pop up 100% of the time. The problem is that they only go down maybe one out of every 50 trys, and Im not exagerating the number. I usually have to manualy put them down at night, so I wont have to deal with it in the daytime the next day. Now heres my question, if they gears were stripped, would the headlights still go up every single time? Also, if the gears were stripped, would I be able to manualy put the lights down? Just FYI Ive never had the loud grinding noise issue. Any suggestions? Im at the point where Im about to buy 2 new motors from ebay.
Old May 10, 2007 | 07:01 PM
96slow6's Avatar
Do they act like they want to go down? Like start to go down but then stop? Do you here the motor turning?
Old May 10, 2007 | 07:53 PM
They DONT act like they wanna go down. And no, I really dont hear anything either.
Old May 11, 2007 | 08:39 AM
blownta00's Avatar
if the gears are stripped, u can still move the light down manually.
Old May 12, 2007 | 03:10 PM
thanks for that info....t t t
Old May 12, 2007 | 03:19 PM
99nbmws6's Avatar
my friend had this problem before then they just stopped going up and down eventuly. his problem was a plug was cruoted (sp) so there was a bad connection. try the plug might be the problem.
Old May 12, 2007 | 10:24 PM
Where is this plug located?
Old May 12, 2007 | 11:04 PM
Tainted's Avatar
the main plug is under the headlight in the corners. youre gonna ahve to take uot the air damming under the car to get to it. its gonan be by the fender and mounting bracket its a big purple one.
Old May 12, 2007 | 11:08 PM
LS1_TA_2002's Avatar
Screw the flip-ups and just go with these.
Click Here
j/k
Old May 13, 2007 | 10:14 AM
99nbmws6's Avatar
pop open the headlights take off the plastic cover should be 2 or 3 screws, put you hand in there and feel around its a white plastic plug, might have to pull it off its plastic tabed down then take a look at it see if the conection is good.
if you can get to the plug with just the plastic piece of then you are going to have to take off the headlight to get to it. its not that hard to do. do a search on hear for trans am headlight and you should find the directions.
good luck
Old May 16, 2007 | 01:48 PM
UCFWS6's Avatar
if you determine its just a bad gear just replace the gear
http://www.bfranker.badz28.com/headlightfix/index.htm
dont waste your money on another motor that will just strip out again
