For those that are having A/C issues and have the V5/7 variable stroke compressors...
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I ran across THIS
The V5/7 compressors DON'T cycle because they are a variable displacement compressor. They just destroke when needed. The LS1 fbody's have the V7 type. I am not sure what the LT1 fbody's have, but I know it's not the V7.
Paul
Paul
Thanks for sharing that tip... That's the problem my '99 T/A is having.... the dealer here in Tampa wants $800 for a new compressor, and I was going to sell the car because I was suspecting that someone had used a sealer in it, in which, pretty much, the whole system must be replaced.
My high side pressure has been 150 - 175, and low side was 65 - 75, with the ambient temp around 85F. I started out thinking my orfice was blown out, so I replace the orfice and accumulator, and it worked ok until I got to full charge, when the low side went from 45 - 75 quickly.. I'm going to replace the RCV as soon as I can find one, but this time I am going to use an adjustable orfice to try and get a little better cooling at idle. Hopefully that should do it..... Once again, thanks
update: I ordered the RCV from a company by the name of Bright Auto. I paid 59.00 for it, which was a savings of around 100 bucks versus what the dealer wanted for it... I installed the RCV, and evac. the system and then charged it up, and voila! I now have Ice Cold A/C.....
