Sponsored by: CARiD
Heat coming in from the floorboards????
Old May 19, 2007 | 02:29 PM
98Trans's Avatar
Default Heat coming in from the floorboards????
I have really hot heat coming in from my floorboards, especially right next to my feet where the tranny is. My gauges read fine, temp is extremely normal...I never use my heater or air conditioner. When I'm driving it feels like my damn heater is on, have to crack the windows just to cool off in the rain.
Its really strange, anyone know what might be causing this???
Thanks!
Old May 20, 2007 | 03:12 AM
shaun's Avatar
well even if you heater is not on keep it on the blue cool side of the ****.
heat will still come from the vents under the dash by your feet.
most gm's do it my camaro does and so does my 04 escalade.
Old May 20, 2007 | 05:41 AM
skeels's Avatar
Yea, my AC/Heater is always on a very low setting even when it is on the off position. Most newer GM vehicles do that. That proboly isnt it, but it would be a nice simple solution if it was. I know mine gets pretty hot around the shif boot, i just thought it was normal.
Old May 20, 2007 | 10:01 AM
Marc 85Z28's Avatar
2 culprits here...
1. Because of the RWD V8 drivetrain layout, the exhaust heats up the floorboards even with the proper heat shielding in place. Normal characteristic of just about every RWD V8 I've ever driven. It gets MUCH worse with uncoated headers!
2. Improper use or malfunction of the HVAC system. Hot engine coolant flows to the heater core. With the HVAC system in the OFF setting, the lack of vacuum opens up the DEFROST and FLOOR doors. Driving around creates pressure at the base of the windshield (HVAC fresh air inlet) and moves air through the HVAC system even with the fan off. Hot heater core + open floor door + airflow = hot floorboards. Some manufacturers incorporate a fresh air/recirculate manual mode that is selectable even with the HVAC off. A VERY good idea!
Old May 20, 2007 | 01:18 PM
98Trans's Avatar
Thanks guys! I'll try a few tricks and figure it out!
Old May 20, 2007 | 08:08 PM
jond99's Avatar
After owning a few fbods i figured it was just a normal thing
Old May 21, 2007 | 12:17 PM
slvr98camaro's Avatar
yeah, turn it to the cold setting, and you will have cold air blowing in.
Old May 21, 2007 | 12:27 PM
xBROKEx's Avatar
Originally Posted by Marc 85Z28
2 culprits here...
pretty much any vehicle ive owned thats had after market header and off road pipe has done this. Even my swapped civic and it was only a 1.8L.
Old May 21, 2007 | 09:14 PM
keliente's Avatar
lol it is. It's a nice foot warmer when you've got the t-tops off on a sort of warm spring/summer evening
Old May 21, 2007 | 09:22 PM
staringback05's Avatar
i turn mine on and roll down the windows....serves several purposes....N.FL air at night is still pretty cool
Old May 21, 2007 | 11:01 PM
blownta00's Avatar
i get that when im on the express-my feet start sweating
