Sponsored by: CARiD
Surging lights
Old May 23, 2007 | 11:00 PM
KillerD's Avatar
Default Surging lights
The lights in my SS surge a lot of the time and is really noticeable at night. It affects all the lights (radio, headlights, instruments, etc.). Ive got stock pulleys and a optima red top battery.
I had this same problem in my 95Z but thought it was my under drive pulleys causing it.
Has anyone else experienced this problem and have a fix for it?
Thanks,
Mike
Old May 23, 2007 | 11:08 PM
staringback05's Avatar
electrical problems are common in fbodys, im having problems with my car killing batteries right now and its not the alternator, i also had the light surging problem....the wires in these cars tend to not carry a good load, due to heat and being a thin guage...i would look into testing load on some of your wires, also check grounds, sockets for corrosion, and alternator strength
Old May 24, 2007 | 07:33 AM
01sschris's Avatar
I have experienced this in my 96 SS when I had it and also experience it in my 01 SS I currently have. I haven't been able to figure out what is causing it. I tried to have the dealer look into it when I first got the 96, they gave me the "unable to duplicate the customer complaint"
I know exactly what your experiencing, but I don't know if it is a cause for concern other than being annoying while driving.
Chris
Old May 24, 2007 | 01:21 PM
Ntimid8r7's Avatar
I have the same exact deal with my SS. Have not been able to find it anywhere. I guess its just one of those little quirks that we have to deal with. A friend of mine even went through it who has one of many ASE certifications couldnt find where it would be coming from either.
Old May 24, 2007 | 01:46 PM
Greggy's Avatar
can you say alternator.
Do the lights surge with the engine off?
My lights use to flicker at low rpm/idle. Alernator died completely... Replaced.. Flickering gone.
Surging to me sounds alot brighter and more intense to me than flickering though.
Old May 24, 2007 | 02:41 PM
LS69TA's Avatar
Probably one of the POS alternators. Mine was doing the same thing. New alternator fixed the problem.
Old May 24, 2007 | 03:02 PM
Ntimid8r7's Avatar
nope. new alternator, battery cables etc. did not solve the prob.
Old May 24, 2007 | 03:40 PM
^^^ exactly, i have a new alternator also...its more or less in bad grounds and weak cables...
Old May 24, 2007 | 04:38 PM
tylerdj's Avatar
I had this problem in my 99 Z but it's all fine in my 00 TA...I've heard it was just a weak alternator but who knows
Old May 24, 2007 | 06:57 PM
01sschris's Avatar
It wasn't a surge it was a quick dim of all the lights. Periodically, it would happen. Kind of like when the lights dim at the house when starting a motor(saw,drill, etc) It's only noticeable at nightime with the lights on. Can't tell during the day.
Chris
Old May 24, 2007 | 09:33 PM
KillerD's Avatar
Yea its not noticeable during the day time; only at night. It is something I can live with and have been doing for a long time but was just curious if there was a fix for it. I will check the alternator for issues. Other than that I guess Ill just suck it up.
Thanks for the responses!
Mike
Old May 25, 2007 | 06:51 AM
Greggy's Avatar
With the new info. you just provided...That's not an alternator.
That's the draw from the air pump and/or cooling fans kicking on that causes the headlights to dim.
Completely Normal.
