M1 5-40 ?
now do you understand the logic behind it?
i believe the LOW OIL light comes on when you're 1 quart low. 1 quart low in over 4,000 miles isn't that bad and my oil pressure has been great the whole time. it's just the fact that it DID come on when the GC has gone longer several times with no LOW OIL light that shows mobil 1's greater likelihood to be consumed.
What you are saying is not correct. Your generalizations are not correct. Your analogies on not relative. M1, in the general pecking order, is not one of the thinner oils.
If you cling to your ingrained gernalizations, how can anybody take any of your other generalizations seriously? What does any of what you are saying aid the oil conversation in any way other than as an example of what not to believe?
Please, Choco, cast aside for a moment your preconceived notions of what M1 is and actually LOOK at the viscosity numbers of it and the oils around it. It really isn't all that thin. Plus, here's a thought: Consumption is not directly correlative to thinness. Thinness is not directly correlative to consumption. There are engines that don't consume M1. There are thin oils that aren't consumed as a matter of course.
GC is a good oil, but the pedestal it is on is not nearly as tall as your shortsightedness would lead you to believe. There are other oils that produce excellent numbers and don't have consumption problems. Pennzoil Platinum comes to mind, and it's about 10k times easier to acquire.
Get a grip, Man!
stop looking at your chart. start looking at reality. i have real results. you have a jpg file.
Get a grip, Man!
You have gathered around you all your prejudices and opinions and will entertain no other ideas. Best of luck to you. I won't argue any more about it since you are obviously here for the argument and not the exchange of information.
My time is better spent elsewhere. Enjoy the rest of your weekend.
Cheers.
1.) mobil 1 is thin. regardless if other oils are thinner or not, mobil 1 is still thin in all its varieties.
2.) most everyone i've ever talked to running a mobil 1 5W-30 or 10W-30 has consumption issues. i've gotten many people to switch over from mobil 1 to GC and their consumption issues stopped altogether or decreased dramatically. i switched from GC to a 40 weight mobil 1 - a much better oil than a 30 weight - and i still consumed more.
3.) i didn't come here for the argument. you did. you keep waving a useless chart in front of my face when i have real world effects in my corner. i don't care about a useless number, i care about how the oil actually performs. mobil 1 in EVERY weight is outperformed by other oils out there. it's mediocre and very overpriced for what you get.
i wish you would understand that i'm not arguing numbers. numbers are completely useless in this situation. this is all about results. you fail to acknowledge my real world experience because you have a chart with numbers on it. so be it.
You are saying M1 oils (all) are thin. They prove themselves thin by the simple fact that you, and others you have met in some way, have consumption problems?
And, that, regardless of M1's relative position on any old stinkin' chart, they are thin, Thin, THIN....regardless of any viscosity they may have or their position on the oil viscosity heirarchy?
And, finally, that the fact that your car (and others) consume M1, that there can be no other conclusion but that M1 is thin...regardless of its actual viscosity numbers?
Does that just about get it?
why do i say that mobil 1 is a thin oil? because compared to conventional oils - the oil i base my opinions off of - it is pretty darn thin. it's very light compared to other synthetics like GC. it shears down a lot more easily, thinning it out even more and making it more easy to be devoured by my engine. the real world has showed me mobil 1 is just an inferior oil. it's not the worst out there for sure, but it's got a lot of catching up to do before it reaches GC standards.
FWIW, GC is on sale this week at autozone for $4.49. i'm thinking about trying to return my mobil 1 at another autozone and hoping they have GC in stock.
Castrol lists density of 0w-30 Euro formula as .847 kg/litre. UK & German tech data sheets (TDS) list it as .838 kg/litre.
M1 lists 5w-30 on their TDS at .8 kg/litre.
That's a difference of only 5.5% at most, 4.4% at least. A few ounces. 7.05 lb/gallon vs 7.43 lb/gallon. That's hardly, "...mobil 1 weighs half that of a quart of GC..."
But it's only an unimportant number, huh?
"My opinion carries greater weight than actual numbers."
Ok. We're done here.
Three of the GC bottles weighed 1lb 14.7oz. One weighed 1lb 14.9oz. The M1 bottle weighed 1lb 14.5oz.
The weight in grams was GC/871g, M1/864g. I don't consider 7g or .2 oz to be considerable, nor even noteworthy.
Looking at the Mobil website, I see the density of M1 0w-40 is .855 kg/litre. M1 5w-40 TD is .854. Again, GC is .838 and M1 5w-30 is .8.
I think the mistake is equating "heavier" weight oil as being literally so much heavier. Yes, perhaps it is, but on a much lesser scale than you are imagining. Consequently, the opposite is also being perpetrated by equating a "lighter" viscosity oil as being actually light, thin, or otherwise etheral. Such is not the case, and much of your opinion (which you state with the confidence of it being dead fact) is evidently based upon a very mis-calibrated scale. By stating the simple fact that M1 is known to be an oil that has consumption, it does not logically follow that it must, therefore, be a thin oil. Since there are many thinner oils that are not consumed in vehicles, do they then logically not exist?
Again, though GC may be thicker than M1, that doesn't make M1 thin. GC is almost the most viscous 30wt there is, and M1 5w-30 is greater than mid-pack in viscosity. But if it were only viscosity (thickness) that was important, there are many more viscous oils, and I don't hear anyone discussing them with the reverence they save for GC.
I'm switching to an M1 product, can't find GC any more around here. I drive less than 3000 miles per year, don't race, store in winter, change in spring (go ahead, jump on me about that), add if I need to. So I figure to have a good long life regardless.
That said, Choco - I've got a quart and a half of GC left on my workbench. I'll send it to you if you pay for shipping. If anyone in this world should have it, you should. Lemme know.
