Dexcool or the Green Stuff???
for those that think GM uses dexcool because it's the best for our engines, you're sadly mistaken and you've fallen into the trap. again, the pontiac vibe/toyota matrix is the best example. they both use the same exact motors. GM makes you put in dexcool while toyota FORBIDS it in the EXACT SAME MOTOR. it's all about GM's money. this is why GM cars chew up water pumps more than others (ask mechanics who see them).
dexcool FTL.
I've owned enough dexcool cars to know that nothing is wrong with the stuff if you change it as often as you would with green. I've got a '96 Bonneville that's been running dexcool for 11 years now without issues related to the coolant (no corrosion, no gel, no gunk, stock radiator is clean as a whistle on the inside). I get it flushed every 2-3 years.
As for it not protecting the engine from corrosion for 5000 miles (true or not), this has not caused me any issues. I've actually never put 5000 miles on any batch of dexcool in my Camaro or Trans Am because I don't drive the cars often enough to reach that mileage during my change interval. Oddly enough, I don't have any cooling system issues on my '98 car that is now 9 years old with a 100% stock cooling system, and when I sold my Trans Am at 4+ years old, that one had no corrosion issues either.
You can praise the green stuff all you want. My own personal experiance is worth far more to me than any articles or info posted from any source. IMO, it's all about proper change interval and the reason why so many people see issues with it is due to following GMs flawed advice of a 5 year/150k change interval. People get it in their head that this stuff can actually last that long, therefore they wind up with issues. I'll bet that's why other OEMs won't let people use dex in their cooling systems that are shared with GM, because they don't want their customers thinking they can leave that stuff in for 150k.
Just seems odd to me that if dex is SOOOOOOOOOOO bad, why is it that I own 4 cars at the moment with dex (and have had many others), but I never have any premature cooling system issues? Or gunk build up? Or gel? I'll tell you why. Proper maintenance (meaning more regular change interval than recommended). It goes a long way.
Here is what I've seen personally: Dexcool changed every 2-3 years = no premature problems, no corrosion, no gel, no long term issues year after year.
I actually trust my own experiances over anything else. If an ASE master certified tech tells me something that I've seen to be untrue over the last 10-12 years of my own personal experiance, then I'll ALWAYS go with what I know to be true from what I've seen personally under my own care. I've got friends that are ASE techs, and I can tell you that they base their opinions on what they see in the field just like any other profession. And what they see in the field are a bunch of uninformed or just uncaring people that actually beleive that you can leave this stuff in for so long. It's obvious that they're going to see a lot of failures, because the average car buyer doesn't even barely do the factory recommended maintenance, much less do better than factory maintenance.
Works like this.......
GM says it's good for 5/150, so people leave it in that long (or longer) and then go to their tech for service when they have cooling system issues on the 5th or 6th year. Then the tech says "yeah, they all have issues just like yours, this dex stuff is bad". On the other hand, these techs don't see cars like mine with all those dex related problems because mine gets changed every 2-3 years, so all they ever see is what happens when people listen to the factory service recommendation.
So what should the techs actually be telling people? They should be saying, "yeah, dex doesn't really last any longer than the old stuff. GM's recommendation sucks."
But they don't say that, because they won't often see just how much better a cooling system looks when the dex is changed more often. They rarely meet a customer like myself that is always changing fluids much more often than recommended and thus doesn't have any problems with my stock cooling systems. The people they meet/cars they see (and thus base their opinions on) are usually the type that get a Jiffy Lube oil change every so often and rarely receive any other sort of maintenance until something breaks.
I have 4 cars ('96-'04) sitting in my garage and driveway that are living proof of my experiance, the fact that when you change dex as often as you would with the green you won't have any premature issues related strictly to the coolant. What more proof do I need? Well, actually I don't need any more. That's why the words of ASE techs that I've never met don't mean much to me.
If I had problems myself, or had no prior experiance at all with the topic than maybe I could agree, but in this case I cannot. I have to go with what I've seen based on my own service schedule.Now, I'll agree that dexcool might have some compatibility issues with older gasket material when used in some of the engines that were designed prior to dex's introduction. I'm sure that in the mid-'90s many new cars came with old engine designs using gaskets that were "pre-dex" although they were given a dex factory fill and they didn't bother to update them. I don't think this is an issue with LS1s.
As for green vs dex on a 2 year change interval, I still prefer the dex. Reason being (as I've mentioned to you before), even with good maintenace pratices (meaning proper change interval for the green), it seems that the inside of my radiators just don't stay as clean over the years. With dex, I don't seem to get nearly as much of that ash-colored cement like film on the inside of the radiator tanks....actually little or none at all with the dex. Granted, I've never actually run green and dex in the same exact radiator, so maybe the material used to make newer radiators is more resistant? I really can't answer that, but I'll just stick with what's been working for me.
In the end, both dex and green can be/are harmful if left in for many years, so that's a draw as I see it. But will dex be the direct cause of premature cooling system failure on a new(er) GM engine design (LS1 or newer) if changed every 2-3 years? HIGHLY doubtful.
So here is what I think GM did wrong:
1) Gave (and is still giving) a poor factory recommendation for the coolant change interval with dexcool.
2) Put Dexcool into some older engine designs with older gasket composition that was not originally designed for use with dexcool (like the older 3.8L, and the 4.3L for example) and still gave the same flawed recommended change interval further compounding the issue.
Not sure about you, but in my world, $1 isn't even something I would waste time thinking about.
GM's recommendation's are ridiculous at times. I think my manual says change the diff fluid at like 150k if you're not using it for towing. That's absurd and would consider it neglect to wait that long.
I think the dex will last longer compared to the green, maybe a year or 2 longer is probably realistic, not 3.
I notice the same thing as you do RPM, my cooling system looks MUCH cleaner than any other car I've owned which had green in it.
