Sponsored by: CARiD
car wont start??? NEED HELP!!!
Old Jun 1, 2007 | 08:42 PM
stroked383z's Avatar
Default car wont start??? NEED HELP!!!
this morning i went out to my car going to my local tire place. i was cranking the car and my fingers slipped off the keys before the car finished starting. well the car made a weird surging noise and wouldnt start at all after that??? i dont know what it is unless it is just flooded out??? i changed the spark plugs to NGK TR55 Iridiums, checked for computer codes, check all the fuses, checked all the relays in the fuse box under the hood, i made sure i was getting spark, and made sure it had plenty of gas. i can hear the fuel pump kicking on and can smell fuel when i try to crank it. i've also got a set of MSD 8.5's coming in the next few days. the car only has 32000 miles on it. what should i do
Old Jun 5, 2007 | 08:39 AM
Anthony Williams's Avatar
Dose it crank if not, try starting it in neutral or rocking the car and then starting it - If it dose crank start with the cheapest thing first starter, flywheel etc.
