Sponsored by: CARiD
What is this noise?
Old May 3, 2003 | 12:01 AM
JimMueller's Avatar
Default What is this noise?
Engine off, key in run position so that steering wheel will rotate. When I rotate it counterclockwise I hear a clank; the otherway it doesn't make a noise and just wants to slow down. What should I check?
Old May 3, 2003 | 07:17 AM
unit213's Avatar
Administrator
Default Re: What is this noise?
Not sure. If I were you I'd put the car on jackstands and have someone turn the wheel while your underneath the car.
