Wires Touched now no power
Was wiring up some autometer guages this morning and a wire touched another and we had a small spark. Probably not the smartest idea I didnt disconnect the battery. The car was running to see if everything was working right. We shut the car off then tried to fire it back up about 5 minutes later and nothing. When you turn the key over to get power for accesories in the car everything works from the radio to the power seats to the windows, the only scary thing is that when you have it turned over for just power for accesories the odometer does not come on along with the dummy lights in the dash. The car will not even attempt to turn over when you try to start it. Where is the starter fuseable link on these cars? I had someone originally hook 1 of the guages up awhile ago and a wire was ran into the fuse box by the headlight switch to the IGN spot for some unknown reason and I did not know til today after it sparked and we started looking for the problem. No fuses are blown we switched some relays around they are all good. Headlights work, fan blower works, cig lighter works, all the dome lights work, seat controls, stereo works, accesories on the steering wheel works. We tried basic things like unplugging stuff so I dont know. What pisses me off is the guy who installed it first didnt fuse it or anything its just wired into the fuse box.
