Lights not working: no taillights , dash , or hazard
Old 06-10-2007, 07:31 PM
JAvenger007's Avatar
Default Lights not working: no taillights , dash , or hazard
Car is a 97 camaro RS.
The dash lights don't work, even when headlights are flipped on. Also, neither of the taillights work. The lights used to light up while driving and then not light when braking, but now they wont light at all. Hazard lights are out as well.
Tried new bulbs in every socket. Also tried the trick where put the turn signal on and hit the brakes...still no luck. Any insight?
Old 06-10-2007, 07:48 PM
Tainted's Avatar
tail lamps fuse i think its a 20
Old 06-10-2007, 07:58 PM
already checked the fuse. Is there one or two?
Old 06-10-2007, 09:48 PM
Tainted's Avatar
just 1 its labeled TAIL LMPS I think. I had the same problem and that was the fuse that caused it all
Old 06-10-2007, 09:53 PM
UCFWS6's Avatar
I once had my brake lights stop working on my old 95, it turned out that the turn signal lever, arm, switch, whatever you call it, was bad. I dont know if that could also have an effect on the other things you mentioned...
Quick Reply: Lights not working: no taillights , dash , or hazard
