Sponsored by: CARiD
HELP.driver side window just sopped going up or down
Old Jun 11, 2007 | 07:07 PM
HIZPANICGUY21's Avatar
Default HELP.driver side window just sopped going up or down
the window motor is 6 or so months old..this is the weird part about it.all the others controls on the driver's side switches work....i can control the passengers window normally..i can lock/unlock both doors from drivers side control switches..i can reposition both driver and passenger side mirriors..the only thing i cant do is control my drivers side window..it just took a **** on me..would anyone know what the hell might be wrong with this crap
Old Jun 11, 2007 | 07:17 PM
tennz28's Avatar
Motor from AZ, install guide from shoebox!
Old Jun 11, 2007 | 10:04 PM
i highly doubt its the window motor since 1- its about 6 months old, 2-the window just took a **** on me..just stopped working (not like when the motor goes out, window stops, goes up 1/2 inch, stops etc..) mines just all of a sudden stopped functioning
but anyway...this is what i was thinking....since i can still control the passenger side window..does that mean that....(see illustration below)
Old Jun 12, 2007 | 08:28 AM
tennz28's Avatar
Maybe the connector plug came undone from the window motor? Also its no so far fetched that the new motor would die again so fast, it happens alot with these cars. Take the door panel off an see if that plug came loose, start with the easy fix first.
Old Jun 12, 2007 | 12:18 PM
Youre Right..thanks For The Tip.
Old Jun 13, 2007 | 03:53 AM
No..everything Is Connected..so Im Going To Do A Test On The Wires Coming To The Driver Window Switch..and Then Take It From There..ill Let Everyone Know How It Turns Out
Old Jun 13, 2007 | 07:49 PM
gnomee's Avatar
I would jumper the wires from the switch to determine if it is the switch or not. If not the switch, then it is the express down module. It is located under the driverside dash above the hump. Black box with about 6 wires going to it in one plug.
Old Jun 13, 2007 | 10:11 PM
thanks for the info...but I GOT IT FIXED.... i was right. it was the switches!!!! got it from the dealer for $19
