Sponsored by: CARiD
What is going on?!?
Old Jun 12, 2007 | 09:59 PM
98Camarod's Avatar
Default What is going on?!?
I was sitting at a light and out of no where my tach starts jumping around and some how I was going between 5 and 15mph at a stop light. My check gauges light was flickering and I dont know what the hell is the matter. I recently put on a ls6 intake but other than that nothing has changed. The tach would jump around but the engine rpm appeared to stay at a steady rate.
Is this charging related or what? (Search sends you to google)
Old Jun 13, 2007 | 02:37 AM
staringback05's Avatar
check and make sure you didnt tug on the excitor wire going to the alternator when you installed the ls6 manifold, check your sensor arrangements, and then check load on your power wires
Old Jun 13, 2007 | 03:58 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Something sounds like it is shorting out. Break out the volt meter.
Old Jun 13, 2007 | 08:45 PM
98Camarod's Avatar
The plot has thickened. I had to get something out of my car and used the keyless and it didn't work. So I thought, maybe the battery is dead in the remote. I figured I might was well check to see if the car will start and it didn't. I'm going to throw a charger on there tomorrow and see if I can figure this out.
Old Jun 14, 2007 | 09:31 AM
98Camarod's Avatar
You gotta love the easy fixes. The was a bad connection right where my nitrous toggle switch was wired into. Funny thing is, it's been working for over 6 months and all of a sudden the connection took a dump. I got lucky and it was the first thing I checked. I didn't even need to charge the batter it fired right up.
