Help ! Abs - Tech2 Diagnostic Tool
Sounds like you are a shop. In that case, if you really want a Tech2 you can purchase them on ebay from time to time for about 2000 dollars. A cheaper solution is to use a tuning suite like EFI-Live to scan for trouble codes that most readers won't get. EFI-Live will pull codes from the ABS Module and it costs a lot less!! If a low cash route is for you just get the dealer to pull the code. They will run 70 dollars I am sure.
Knowing the code would definately help. We might be able to help you then. Otherwise you are left with getting the diagram out and manualy checking all the connections. Or replacing parts.
Tell us more about the car. Wrecked? Just stopped working?
Hope you get it fixed. I have seen everything with my car, too. I guess it is half the adventure!
