Sponsored by: CARiD
A/C blows hot
Old Jun 13, 2007 | 08:48 PM
Mystic 98 TA's Avatar
Default A/C blows hot
Hey guys, when I turn the AC on, the compressor blows air, it just comes in at outside temps. Not cool when its about 100* outside. Low Freon?? if so, how do i replace it?? Is there something else I could be missing?
-Charlie
Old Jun 13, 2007 | 09:09 PM
Jon5212's Avatar
More than likely you are low on freon, does the compressor come on at all? If not you are probably low on refrigerant. You fill it on the low side of the A/C line, R-134 has 2 different size fittings so you can't mix them up when adding R134.
Old Jun 13, 2007 | 09:46 PM
The compressor comes on. When refilling, am I supposed to have the compressor on when refilling??? A/C newb here . Any pics??
Old Jun 13, 2007 | 11:25 PM
waldershrek's Avatar
I'm not sure how you do it exactly with the little cans. I know from when I worked in a shop that had the AC machine you do it with the engine off.
Old Jun 14, 2007 | 06:11 AM
Jon5212's Avatar
no when you are filling from cans you are suppose to have the engine running and at set the A/C to MAX A/C, also you fill it with the can upside down.
edit: make sure you don't overfill it.
Old Jun 14, 2007 | 06:33 AM
Shinigami2x4's Avatar
Overfilling is very bad..they have a bottle for people with out a license that comes with a gauge to tell you how much needed and danger of overfilling.
Old Jun 14, 2007 | 08:06 AM
Jon5212's Avatar
^^^ you don't have to have a license for 134, only if you are working in a shop. For the home DIY you don't have to have a license. Only to buy R-12 and R-22.
Old Jun 16, 2007 | 12:52 AM
Shamson5.7's Avatar
Stupid question...but I how do I tell if the compressor comes on?
Old Jun 19, 2007 | 12:06 PM
Jon5212's Avatar
you should see the clutch engage on the front of the compressor. Should also notice your rpm drop a slight bit when the car is idling.
