Sponsored by: CARiD
Changing oil filter
Old Jun 16, 2007 | 08:56 PM
The Gentlemen's Avatar
Default Changing oil filter
This may be a stupid question...but how do you all change your oil filter with Long Tubes???? I am having the damndest time getting a filter wrench on the thing. I can't even get it tight. Are there any tricks or am I just an idiot?
If I can't get this tonight...is it bad to change the oil, leave the old filter, and drive tonight and tomorrow until I can get it to a shop?
Thanks in advance.
Old Jun 16, 2007 | 09:13 PM
~RedLineLs1~'s Avatar
Stick a screwdriver through the side and twist. Next time don't tighten the filter so much. Prime the rubber seal with some oil and hand tighten it.
Old Jun 16, 2007 | 09:56 PM
INMY01TA's Avatar
Actually the 1st time I changed my filter after installing long tubes was a little tricky. I had no problem getting a filter wrench on the bottom tho.
Old Jun 16, 2007 | 10:17 PM
Well the screwdriver trick didn't work....kinda. The old, time-tested method of pushing a screwdriver through the filter worked, finally. talk about a mess though! Thanks for the input guys. Next time this won't be a problem as I won't be going to Valvoline anymore.
Old Jun 16, 2007 | 10:20 PM
INMY01TA's Avatar
What filter is it? If it's a short one I could see how it would be harder to get a filter wrench on it with a long tube in the way. I run the AC Delco pf 61, comes down far enough to get it on there.
Old Jun 16, 2007 | 10:47 PM
sroach20's Avatar
go get one of those rubber strap wrenches. get the rubber tight and you can point the handle straight down. normally like $15 at a parts place. they come in handy on other stuff all the time.
Old Jun 16, 2007 | 11:10 PM
Rescue Ranger's Avatar
Get a K&N Oil Filter. It has a nut on the bottom of the body to allow easy on/off. Perfect for cars w/ Longtubes.
Old Jun 17, 2007 | 02:53 PM
blownta00's Avatar
k and n filter are expensive, like inmy01ta said theres another filter that they uses on trucks that the 5.7 i think it is 3980
Old Jun 17, 2007 | 06:31 PM
black01_WS6's Avatar
yup what he said, best filter out on the market right now.
