Sponsored by: CARiD
Problem w/ ARP stud removal
Old Jun 19, 2007 | 09:56 AM
Dmoney's Avatar
Default Problem w/ ARP stud removal
Any one have a problem removing the studs???? I'm having a bitch of a time removing 2 of the little studs. I've already twisted 2 socket tips and I'm afraid to strip out the tip of the stud and never get it out. What do you guys use????
Old Jun 20, 2007 | 11:41 PM
Samba242's Avatar
Not sure which type studs you are talking about, but I had to grind two sides flat on an ARP header stud and twist it with pliers once to get one out. Did you use assembly lube when you installed them?
