Sponsored by: CARiD
oil leak from ac compressor
Old Jun 24, 2007 | 11:57 AM
banditb1999's Avatar
Default oil leak from ac compressor
I just did my first engine oil change on my new to me 98ss. It has around 45,000 miles. I noticed that the ac compressor has some oil pooling around at the bottom and that the rubber boot on the steering system also has some of the oil on it. The car is kept parked on the grass next to my garage so I have never noticed the oil. The ac seems to be blowing strong and cold. What should I do? Are there seals that can be replaced? Will doing nothing cause other parts of the ac system to break? Thanks
Old May 3, 2009 | 09:56 PM
martinls1's Avatar
So what ever happened with your compressor? Did it fail? I have the same problem with mine (leaking oil).....but air is cold and the compressor doesnt make any noise?
Old May 3, 2009 | 10:13 PM
TAtoad's Avatar
what colors the oil??? compressor oil is clear
Old May 3, 2009 | 10:16 PM
loyolacub68's Avatar
This guy has not been on here since 2008, I don't think this thread is coming back.
Old May 3, 2009 | 10:19 PM
silverz28camaro's Avatar
I have a stock 98 compressor for sale....$80 shipped
Old May 3, 2009 | 10:25 PM
martinls1's Avatar
Yeah I saw the last date he was on after I posted. The oil is clear, yeah I know its coming from the compressor. Its just weird that, its been leaking for the last few months and the air still works. I know about ac systems but just would have thought that if your leaking oil for that long that the compressor would be squealing or have taken a dump by now. Its not leaking from the hose connection going into the compressor but its leaking from one of the joints on the compressor casing.
I guess it will eventually go..........
Old May 3, 2009 | 10:45 PM
MrElectric03's Avatar
Probably leaking on the shaft behind the clutch, seriously unless you dont intend to use your ac fix it now. Your compressor will go out and fill your system with crap. Im a trained a/c specialist and that **** gets expensive real quick.
Old May 4, 2009 | 03:32 PM
samson_420's Avatar
All true, if the compressor does chew itself on the inside. All the crap will be sent through the whole AC system.
Old Jun 19, 2009 | 02:22 AM
02sleeperz28's Avatar
I have a A/C compressor out of my 02 TA for sale. I have pics also. 100 bucks shipped OBO.
Old Jun 19, 2009 | 10:57 AM
samson_420's Avatar
The dead thread revival tour continues
