Sponsored by: CARiD
trying to remove alternator.
Old Jun 25, 2007 | 09:53 AM
6']['9's Avatar
Default trying to remove alternator.
im trying to remove the alternator and i got the 15mm bolts off but the bolt in the back that goes to the battery which is inbetween 2 1/2mm bolts doesnt want to come loose. I tried to put a wrench on the last bolt and it doesnt fit. I also tried needle nose pliers and i cant get it to budge.
Another thing the harness that has that red wire came out. so besides being a dumbass what can i do to remove that bolt and also what can i do about the wire harness.
thanks
Old Jun 25, 2007 | 10:39 AM
GregWS6&z28's Avatar
all I can tell you is, I used a stubby 3/8 drive rachet and maybe an extension to get to the back bolt, and as far as the power wire goes I used a smaller socket on that too. It's easy and obvious what you need to do. just try a little harder.
Old Jun 25, 2007 | 02:30 PM
staringback05's Avatar
get a shallow well socket and a extension and it should break loose....YOU HAVE TO fix that excitor wire harness...its whats going to charge your battery
Old Jun 25, 2007 | 08:15 PM
6']['9's Avatar
how do i do that?
Old Jun 25, 2007 | 08:27 PM
Camaroz's Avatar
Originally Posted by 6']['9
how do i do that?
Not easily... your going to have to find a way to get that wire back into the weatherpack connector.. Depending on where the wire broke will determine how hard that's going to be.
Old Jun 25, 2007 | 08:53 PM
Dmoney's Avatar
Just buy a new one from the dealership. They are about $35 and they'll give you one that has all four wires, just cut the ones you don't need. That's what I did............
Old Jun 25, 2007 | 09:35 PM
6']['9's Avatar
thats the kind of answer i was looking for. thanks
Old Jun 26, 2007 | 03:35 PM
Mike44138's Avatar
Or waytekwire.com will sell you weather pack connectors and pins.
Old Jun 26, 2007 | 07:27 PM
6']['9's Avatar
i got it from the dealer for 20 bucks so ill try that. thanks
