Anybody use this Maxi seal stuff?
A 2 step system that will seal metal and rubber. I dont know if I should use it. With the small leak in my system and this quote
I dont want everything in my system to seize up, that leak has been there for a week. What do you guys think?
If no Maxi-seal then can I just cut out the section that is leaking (3 inches) and use some radiator hose with worm gear clamps, then call it a day?
Our Maxi Seal (MRL-2) seals both rubber and metal leaks. The metal leak sealer works by reacting with air and condensed moisture outside the system at the site of the leak.
