Hearing A Noise.... Power Steering Pump?
*The only way i can describe the noise, is that it sounds like when you put a manual transmission vehicle in reverse and go kind of fast and it makes a whining noise. But my car makes that noise constantly.
SO my question is... does it sound like the pump got taken out because of the low fluid level.. or is this a completely different problem??
Note: there were no leaks from the power steering at all, but i have had to add fluid several times.. even had it up on a hoist at work to check for leaks and there are none.
I had my power steering flushed about a month ago... could it posssibly be air in the system? Or does it sound like i need to start shopping for some parts?
sorry for the book.
