Not wanting to start, surging, both intermittently
Thanks,
Josh
Crank Shaft Position sensor can cause all of those problems...and it may not ever show a SES light. Mine didn't.
Plugs could be dirty and after it runs for a little bit they get cleaned off of the crud build-up and than can run smoothly.
Clogged fuel filter?
Clogged fuel injectors?
Bad/failing 02's can cause this too, and they will NOT always give you a SES light either. Mine were bad and I had no SES light, but the scan showed they were not working.
P0128 - ECT
P0135 - O2; Bank 1 sensor 1
P0140 - O2; Bank 1 sensor 2
P0155 - O2; Bank 2 sensor 1
P0160 - O2; Bank 2 sensor 2
i have p0140/p0160 because i didn't use o2 sims for my headers, but i guess i need a new ect and front o2's.
thanks for your help
P0128 - ECT
Do yourself a favor and DO NOT buy the Bosch 02's. Get genuine AC Delco 02 sensors. www.rockauto.com sells them for $74.00 each, less than the dealership.
