Security not letting me start the car. Help!
Originally Posted by CALL911
BTW, I don't really want to change the cars security system. I just want to find out why the car is doing this, and if I can get another key without having to spend the $ from GM.
the thing is those hardware keys are made cheap i went threw three cuz i was to cheap to go to GM finally after saying enough i did and i have not had a problem. check your key see if its dirty and clean it with an eraser. i had the same problem
I'm all for bypassing it as it is a common problem and you WILL sooner or later have a problem with it.My alarm system works just fine.The wiring that they use in the VATS system is PATHETIC.Wires almost as thin as a thread.No shocker that tey breakdown.
But in the end it is your car and I certainly don't make the payments on it so...your call man...I would at least look up the info about bypassing it,might be useful info should you be stranded somewhere.
Good luck...
Good luck...
Thanks again for the info guys. I tried the duplicate key again, and now it is working fine again. The problem is now I am not 100% confident that the duplicate key will work every time and not leave me stranded somewhere.
Would this still be the VATS system since the GM key has never failed me?
Just bypass VATS. It is the resistor in your key that is acting up, not the physical key. The "little chip" is simply a resistor. Go to RadioShack and buy a multimeter to get the correct value for the ohm reading on your key. Then buy that value resistor. Do a search. All you do is solder it inline on a wire underneath the steering wheel. Cover it up in black electrical tape and then put the plastic cover back over all the wires and you are done. I'll try to find the picture I took of the wire you have to solder in to. It is simple as that. $0.99 and 10 minutes of your time and no more worrying.
