GM 4.3L V6 longetivity.
#41
My buddy has an 88 full size pickup with a 6 in it, I think it's the 4.3 but I could be wrong, it has 325,000 on it, and still runs. I'm pretty sure the odometer stopped working about a year ago too, so it might be more.
#42
Originally Posted by Cumbias
Mine is a 4x4 too, the remote oil lines have been leaking since about 120K, thought about replacing them but my mechanic recomemded to leave them as is because the leak was n't too bad and it would cost some pretty labor, how much were yours to replace.
NAPA and some smaller auto parts stores sell the lines from the block to the filter for about $30. They're Dorman brand, and are triple crimped where the fittings meet the hose (the OEM lines are double crimped). Finding the lines from the filter to the cooler was fruitless, so I took the old lines to a hydraulic shop and had them put on AN fittings and use some nice hose. I think that ran about $90.
It's not a fun job at all on a 4x4 because the front diff and front propshaft are in the way of everything. I was replacing my engine mounts at the same time so I had the engine jacked up a few inches and the back of the diff hanging down and it was still difficult to snake everything through. Then you get to put the bolt securing the oil line flange into the block using a wobble socket on about four feet of extensions. Fun.
I'm glad I don't have a small puddle of oil under my truck anymore, but honestly if I hadn't been replacing the engine mounts anyway I'm not sure it would have been worth the hassle.
#44
Originally Posted by Caswell
I replaced them on my own. Both the lines from the block to the remote filter and the lines from the filter to the oil cooler were leaking.
#45
have you had any other major problems besides the tranny. . . .
#46
Ive replace the alternator twice, the first was a stock gm and the second is a Duralast gold one. Installed the last one about a year and a half ago. . seems to be working good so far.
