Sponsored by: CARiD
low coolant level keep coming on?
Old Jul 12, 2007 | 12:36 PM
BlackTBird's Avatar
Default low coolant level keep coming on?
i have a 98 trans am. my coolant light is constantly coming on. i have checked the level many times and i have enough coolant in there. i just changed the water pump and flushed the radiator. the light still comes on. anyone know what might be wrong and how to fix this ???
Old Jul 12, 2007 | 12:44 PM
A-Dub's Avatar
Thats what it does when the sensor goes bad. I just unplugged mine, took care of the problem. The sensor is on the pass side of the radiator about 3/4 of the way to top on the engine side
Old Jul 12, 2007 | 09:25 PM
HIZPANICGUY21's Avatar
dont just unplug it..get a new one..im pretty sure its like $20 or so bucks...easy install
Old Jul 13, 2007 | 08:54 AM
A-Dub's Avatar
Try 40 bucks.......
Old Jul 13, 2007 | 08:55 AM
MrEddie's Avatar
Does coolant leak when replacing?
Old Jul 13, 2007 | 10:13 AM
A-Dub's Avatar
Yes it does
Old Jul 13, 2007 | 01:53 PM
They Saw You Coming Silver.
Old Jul 16, 2007 | 01:25 PM
BlackTBird's Avatar
any specific direction on how to change it
Old Jul 16, 2007 | 02:41 PM
99WS-6's Avatar
<--- same issue only with a 99 ws-6 light always on coolant is fine after a 30min ride or so it goes off
Old Jul 16, 2007 | 04:06 PM
99NMB's Avatar
try checking the radiator cap for **** built up on the rubber part.
Old Jul 17, 2007 | 09:35 AM
waiting2bl33d's Avatar
OMG BEST POST EVER.
just kidding joey.
Old Jul 18, 2007 | 06:28 AM
pjb's Avatar
pjb
is your coolant slimey and oily? I had a PS fluid leak into the cooling system and the contamination of the coolant caused the low coolant sensor to pop the light on. power steering cooler is in the upper radiator pipe, which had an internal leak.
Old Jul 22, 2007 | 06:46 AM
BlackTBird's Avatar
i dont think its leaking. i just remember it started coming on ever since i added some more coolent in there like four months ago. i changed all the coolant after i changed my water pump. and it still comes on. most likely the sensor is out but could it be the type of coolant i used that caused the sensor to go out??
Old Jul 22, 2007 | 07:31 AM
staringback05's Avatar
that sensor tends to go out alot....check the level, if its good just unplug the sensor...it wont have any ill effects and if your a good car owner you check your fluid levels anyway...
Old Jul 23, 2007 | 05:49 PM
Black 99 Bird's Avatar
What kind of coolant did you use?
Old Jul 31, 2007 | 11:57 PM
BlackTBird's Avatar
dexcool 50/50.
