New LS1 owner - engine problems
Help!
P.S. I could try to film it with my phone, but not sure if it will be seen
I would take it to a speed shop for diagnosis immediately for an ESTIMATE and see how badly you've been ripped off.Hopefully you got it very cheap, knowing in advance you were going to get stuck with a lot of repairs.If not, it's a lesson we've all learned!Good Luck.
There is no way I could check the car myself. I relied on some people to check the car. The price was a bit lower than medium but the car is 146K miles. Although owner said he has changed a lot of things. So I was kinda prepared to have some problems, although I didn't know it wouldn't idle when cold, and engine would shake, and the clutch doesn't hold.Next, there are no people in my region that tune american cars. I was the first to try, and I've taken the risk. I have no shops to count on, all I can rely on is online help from ls1tech.com people, and google.com
With your help I hope to build the fastest street car in my region
But for the start, these issues have to be addressed. After that, I would put turbo on it. Not charger, because I don't know anything about them, I was playing with turbos on my Nissan Silvia (managed to get 165hp/liter with some basic mods and extensive ECU tuning).OK, enough of lyrics
Let's get back to the problems, please help to sort them out
Maybe some cylinder or two is not working on idle, and this causes the engine to vibrate at certain rpms? Can it be checked somehow?
I don't like the idea that neither of us saw this car for a couple of months before he got it...
Chuck was fine!
I ask, because I had a similar issue caused by dirty fuel injectors. For about two weeks, when the car was cold, it would idle rough, surge, and then after it warmed up, and I throttled up about 1/3 t o1/2 throttle, it let out a bunch of grey/black smoke and then ran fine, until it cooled back down. I had two injectors on the passenger side plugged, causing lean conditions on two cylinders, and rich on the other two. And finally, after the two weeks, it threw a random misfire code, P0300 if I remember correctly. If you have a tuner, EFI Live or HPTuners, I think you can check for those conditions (help me out here guys on this part
). If not, and you can find someone over there with a GM Tech2, use that to see if you can get into the computer's history and see if anything along those lines comes up. This is just a suggestion of something to look into.....And another thing, you may want to buy a service manual from Helms Inc. if you haven't already, I think it's definately a must, especially for you since you're in Latvia.
Good Luck...
I just hope disc will not move from the center
don't have HP Tuner/EFI Live yet
it was about 20C here when I posted. I have to press pedal for few minutes before it can idle on its own.
there was no book in the trunk
I've checked AFR after cold start - it goes as low as 10:1
That happens with air temp of +40F. Is that normal with that cam? Last edited by Vetal; Dec 6, 2007 at 01:50 AM.
