“Check Gauges” and Voltage Issue
So I was still having the same issue. It doesn’t happen 100% of the time, but very often, maybe 80% of the time. So I removed all the grounds that are visible from the top of the engine bay, cleaned all of them, and reconnected them.
Still having the issue. I read in another post on here, that a persons MAF sensor was causing a similar issue. So I took the MAF off my other Formula, and installed it, just to eliminate that as an issue. Still having the issue.
Does anyone have any suggestions of what it might be? Or what I can try next to possible fix the issue.
Thanks in advance
Nick
Travis
Travis
Car was still having the same issues.
So today I'm pulling out the new alternator I just installed from Autozone, and going to have them replace it, and install the new one. Hope this works. Or else I have no idea what it could possibly be.
Then i get on it a bit, and the ses light comes on, and the volts instantly drop to where the orange starts on the gauge. So I got to my buddies house, and parked it. Later went to go home, and started it up. Was still ot the top of the orange. So I figure I'll try to make it home, what the hell. Start driving and the volts start to drop consitantly as I drive, the car ended up dying just as I pulled into the driveway.
The only thing I can think is that it has to do with the connector that plugs into the top of the alternator.
Any ideas? What exactly does that wire do, and where does it go?
and you said your SES light came on, what code is it?
when my alternator went out, my ses light didnt come on, but my check gauges light did.
I've checked every wire, except the exciter wire. I made sure it wasn't broke from the connector, and made sure it was pluged in, but I'm going to make sure now the connection is good. Make sure the pin is making contact inside the conector.
Still didn't fix the issue.
I want to check to see if the alternator is getting a signal from the exciter wire.
Is there a way I can test this, like hooking up a multimeter to it, and seeing a specifc voltage. I just want to make sure the alternator is getting a signal from the exciter wire. Any info would be appreciated.
Thanks in advance.
I also spliced in a extra connector and ran a direct 12v to the plug on the top of the alternator to trick it into charging. It still wouldn't charge. With the car running and the exciter wire attached, I checked the voltage output directly at the alternator, and it was 9v or so.
So I'm assuming that this alternator is bad also, that would make 2 Autozone ones in a row bad, even though they both tested good on autozones test station.
I'm going to get a Actual AC Delco one and install that. Hopefully that fixes all my issues. If not I'm completely lost and out of ideas.
