Sponsored by: CARiD
Loose Belt
Old Jul 20, 2007 | 02:12 PM
99WS-6's Avatar
Default Loose Belt
My belt squeeks more than it should. i examined the belt and it doesnt seem to be rotting or cracking so i am wondering what bolt to tighting down on to pull that belt alittle tighter
Old Jul 20, 2007 | 02:42 PM
2001NBMZ28's Avatar
Which belt? There's a separate one for the AC compressor. Both are on tensioners and don't require adjustment. Maybe the bearings in one is going bad or an accessory is making noise?
Old Jul 20, 2007 | 03:59 PM
koolaid_kid's Avatar
The tensioners are spring loaded and self adjusting. I would look somewhere else also.
Old Jul 20, 2007 | 04:35 PM
99WS-6's Avatar
alright thank you shortly after i posted this i relised they where self tentioned. i got rida 1 squeek replaced my front brake pads *old onse had 3/4 left but where both snapped. also got rotors re milled. the belt has stopped squeeking now that its been dry alittle out but it also has been wet out past weak. woudlnt hurt to replace both those belts as well :-/ and do my rear set of breaks
