AC oil leaked
I replaced one of the hose assemblies, drier, and orifice tube a few months ago. The shop that did the recharge for me added some oil (don't know how much) but I'm wondering if maybe they added too much? The A/C actually still works just fine (I haven't run it a lot, but it has been run and works well), but I'm worried that there may not be enough oil left in the system and it's just a matter of time before the compressor siezes.
I also can't tell exactly where the leak is. It's NOT around the hose assembly connection. There is a decent build up around the control valve assembly (I think that's what it is). I can't tell for sure if anything was coming out of the pressure relief valve, but it doesn't look like it.
It appears that all the oil dumped pretty much at one time (either when I started the car or after I parked in my garage). Since then, I've seen a couple of drops of oil appear, but after climbing underneath, I can see that it was probably just residual oil/dye dripping from the areas where it had collected.
Here's a picture of the the spot that was left behind.
Is my compressor toast? Is it just some sort of blow off from being overfilled? Should I just get a shop to look at it?
I'm guessing I blew a seal in the compressor, but that everything is still in tact. I'll tell you though, it's hard to not turn that half busted thing on when it's over 100 degrees out. Each time I'm tempted, I just ask myself if I want to have to pay another $80 for a flush and who knows what else I might have to replace. At least I have T-Tops...
