Sponsored by: CARiD
Brake squeeks interpreted?
Old Jul 24, 2007 | 11:15 AM
kaos_'s Avatar
Default Brake squeeks interpreted?
I've got pretty new brakes including new rotors, calipers and pads but the front left brake makes a little squeeking noise sometimes. What does that usually mean? Loose bolt, nut, unsmooth rotor surface? Where should I check for lube? Or WHERE should I lube?
Old Jul 24, 2007 | 12:00 PM
renxwar's Avatar
+1. Got the SAME exact thing happening on the right (passanger) side.
Old Jul 24, 2007 | 12:42 PM
kaos_'s Avatar
what causes it?
Old Jul 24, 2007 | 12:55 PM
staringback05's Avatar
sounds like a little dust left over...you can lube the caliper in three points...also can feel the rotors by finger and see if they are uneven
