Sponsored by: CARiD
headlight problem
Old Aug 7, 2007 | 04:55 PM
gameovergt's Avatar
Default headlight problem
My 2000 Trans Am started making a real bad noise from the driver's side headlight. I popped the hood & its the motor that sits behind the light. It keeps running after I unlock the car with the transponder or turn the car off. Makes a real bad grinding sound. Anyone know why it is doing this?
Thanks,
Kevin
Old Aug 7, 2007 | 04:59 PM
bww3588's Avatar
the plastic gears are stripped. there is a place on here that sells brass replacemnt gears for it. im not sure where tho, as i dont have a T/A. someone will chime in.
Old Aug 7, 2007 | 05:01 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
^ Read above.
Some nice brass headlight gears should fix that problem.
Moving to General Maintenance & Repairs...
Old Aug 7, 2007 | 07:28 PM
VIP1's Avatar
Copy & Paste Moderator
Sticky:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Old Oct 16, 2007 | 01:11 AM
JasonWW's Avatar
Just spreading the word as I just found out about these. HELP (motormite, Dorman) makes a replacement plastic headlight gear for about 15 bucks. Autozone can order them, but it may take a few days to get them in. Part # 42400.
https://www.dormanproducts.com/cgi-b...tegory_list=:0
