Sponsored by: CARiD
Weird window problem
Old Aug 12, 2007 | 09:42 PM
W105's Avatar
Default Weird window problem
My driver side window will not roll down. Whenever the window button is pressed down, the window will roll down 1/4" and then stop while the motor (i guess) makes a loud grinding sound. Any ideas of what this is? Window motor, gears, regulator?? Any help is appreciated.
Old Aug 12, 2007 | 10:52 PM
sroach20's Avatar
sounds like the regulator, unless something came loose and is blocking the path.
Old Aug 14, 2007 | 04:18 PM
W105's Avatar
Thanks, anyone else.
Old Aug 14, 2007 | 08:36 PM
blkbird's Avatar
Can you still hear the motor going?? If not, then that might be the culprit!!
Old Aug 14, 2007 | 08:43 PM
W105's Avatar
Yes, you can still hear the motor trying to roll the window down. Thats why I am wondering if the gears are stripped, or the regulator is messed up.
Old May 19, 2011 | 05:54 PM
pyrice's Avatar
Has anyone found the fix to this? I have the exact same problem. I cant see anything blocking the path but the motor is trying to bring the window down but only goes about 1/4in before it stops and grinds.
Old May 19, 2011 | 06:59 PM
Elthesh's Avatar
Sounds like the motor. On my 91 Trans Am, the passenger motor did the same thing a month back. 1/4 down and a machine gun sound. The motor was bad. I replaced it, and everything was back to normal. Yours is likely bad as well.
