Sponsored by: CARiD
Corrosion removal?
Old Aug 16, 2007 | 03:03 PM
aliensRreal's Avatar
Default Corrosion removal?
My driver's side headlight has some problems. Sometimes it goes up, sometimes it doesn't, sometimes the light is on, sometimes its not. I took the contraption apart using Brent Franker's (I believe that's his name) video. Anyway, when it was all taken apart there seemed to be corrosion in the power plug, hopefully that is the problem. Someone suggested baking soda and it did nothing. Does anyone else have ideas?
Old Aug 17, 2007 | 07:27 PM
ipdking711's Avatar
wd40...???
Old Aug 18, 2007 | 07:32 PM
Thank you for the suggestion, will try it out.
Old Aug 20, 2007 | 11:29 AM
FastB's Avatar
Sprite. The soft drink. You can use that to get corrosion off of battery posts. Seems like it would work here too.
