Sponsored by: CARiD
Ticking
Old Aug 18, 2007 | 11:15 PM
Juje's Avatar
Default Ticking
Ok, so I'm out racing, have my car redlined in 3rd, go for 4th and manage to grab 2nd . Well now I am hearing a ticking at low RPMs. If you pop the hood and are looking at the engine, the sound seems to be coming from the driver side and toward the firewall. I know with this information it could prolly be thousands of things, but I figured it was worth a shot to see. My car still seems to run fine. Its a 98 Z28
Old Aug 18, 2007 | 11:27 PM
SSNISTR's Avatar
Bent pushrods....
Old Aug 19, 2007 | 12:03 AM
Arc00TA's Avatar
I have the same thing, I'm 99% sure its bent pushrod, but right now I don't really care unless it breaks completely. Mine happened after I banged the rev limiter on a 2-3 upshift. It seems to be too much of a hassle to fix if I'm going to do H/C soon anyways.
Old Aug 19, 2007 | 10:31 AM
Juje's Avatar
Ok, thanks guys. So will it not hurt anything else if its a bent push rod?
Old Aug 19, 2007 | 11:50 AM
Greggy's Avatar
My car always has ticked...you sure your not just listening a little harder because you are worried that you may have hurt something?
Old Aug 19, 2007 | 12:28 PM
Juje's Avatar
Well the thought has crossed my mind, but I'm pretty sure this is a new noise.
Old Aug 19, 2007 | 12:39 PM
SSNISTR's Avatar
If it is bend pushrods, get it fixed.......
Are you sure it's not injector noise? Or header ping if you have headers?
Old Aug 19, 2007 | 01:50 PM
Juje's Avatar
I am pretty sure its not injector noise and I don't have headers. I guess I will get it into a shop this week and have her checked out. Thanks for the help.
Old Aug 19, 2007 | 03:10 PM
MasterV8's Avatar
I had ticking does it seem like it's coming from under the car when you're stood outside?
Mine was a loose spark plug, tightened it up and no more ticking, also if you've got LTs check your cats, i also hit a dip in the road chasing a 240sx and it ripped a hole in it, that also made a ticking noise till i replaced it
Old Aug 20, 2007 | 12:36 AM
Arc00TA's Avatar
Mine is very definitely a metallic sound, not exhaust leak etc. Its coming from about dead center on the motor so a pushrod is a good guess. I don't really want to get into it iuntil I do heads but I might swap them out anyways. I have also heard that a bad coilpack makes a similar noise.
Old Aug 20, 2007 | 11:25 AM
FastB's Avatar
It's probably a bent pushrod. Best to get it fixed because it could start causing problems elsewhere. Could throw things out of sync. An engine doesn't work right unless everything is working together.
Old Aug 21, 2007 | 08:12 AM
Juje's Avatar
Well good news. There is nothin wrong with my car. Guess I was just being paranoid. Thanks everybody for your help.
Old Aug 21, 2007 | 06:48 PM
lastcall190's Avatar
...? How did you come to that conclusion? Check the PRs?
-J
