Sponsored by: CARiD
Squeak/squeel on start up
Old Aug 25, 2007 | 12:58 AM
Freaklt1's Avatar
Default Squeak/squeel on start up
The car is a 99 SS and the squeel happens only in the low rpms (1500 and lower) for about the first 5 minutes of starting the car. I know the belt is an original with 58k on it, so I plan to replace this first. However, I really think this sound is coming from one of the pulleys. The squeel also gets louder when I take off and the rpms drop below idle. Any idea which one would squeel at this rpm and go away when it warms up?
Old Aug 25, 2007 | 02:50 AM
SS#2906's Avatar
I think it's definitely one of the two idler pulleys. It's more than likely the one on the driver's side, I would change them both just to be certain.
If you let it slide for now, the squealing is gonna let louder at higher rpm's.
Old Aug 25, 2007 | 03:59 AM
ae13291's Avatar
this is your air pump it is normal operaton nothing to worry bout it circulates clean air in your exaust manifolds to warm up the cats and reduce emissions taking off the air pump will not gain you any horsepower
Old Aug 28, 2007 | 10:47 PM
frisky2101's Avatar
i got the same problem, but i !EGR and !AIR already changed the belt any ideas???
Old Aug 29, 2007 | 09:02 AM
Freaklt1's Avatar
Fixed the problem in about a half an hour. I replaced the belt and repacked the 2 idler pullies with grease. Problem solved. Thanks guys.
Old Aug 29, 2007 | 05:31 PM
frisky2101's Avatar
cool guess I'll try the pullies
