Sponsored by: CARiD
Mechanical Gauge
Old Aug 28, 2007 | 07:33 AM
The93z's Avatar
Default Mechanical Gauge
Sorry did'nt really know where to post this but what exactly is a "mechanical" gauge?
Old Aug 28, 2007 | 08:01 AM
koolaid_kid's Avatar
There are two types of gauges, electrical and mechanical.
An electrical will have a sending unit.
For example an electrical fuel pressure gauge will have a sending unit that connects to the fuel pressure and sends voltages through a wire. A mechanical gauge will have a tube that sends fuel to the gauge.
hope this helps.
Old Aug 28, 2007 | 08:56 AM
jimmyblue's Avatar
Moderator
Mechanical gauges are usually fluid tubes - direct oil,
a bulb-and-vapor (temperature), fuel. For fuel you
want to also have an isolator in case of failure, a
gasoline bath is unpleasant at best and can go downhill
in a flash Similarly I would not have a direct oil
pressure gauge in -my- pimpy clean interior.
The only benefit of mechanical gauges is cheapness.
Thing is if you break the pressure tube on a temperature
gauge the whole assembly is trash. Nick a wire on an
electrical, piece of electrical tape and you're back on
line. Threading the tubes through the firewall can suck
especially when they are needing a lot of bends etc.
Old Aug 28, 2007 | 05:20 PM
The93z's Avatar
Ok man so tell me this guys. I bought my car used and on the temp gauge sensor there is a tube instead of a wire coming from the sensor like my buddies z28. I bought a gauge (not knowing any of this yet) and the gauge light would only come on and the temp gauge would not work. My stock one dosent work either. So I would have to buy a mechanical water temp gauge in order for it to work?
Old Aug 29, 2007 | 03:35 AM
waldershrek's Avatar
You must have bought an electrical gauge and the sending unit is mechanical. I would just change the sending unit to an electrical one. I used to have a mechanical oil pressure gauge in my first 3rd gen and one day after awhile it starting leaking (unknown to me) and when I got home after driving all day the floor and my pants were covered in oil.
Old Aug 29, 2007 | 07:33 AM
The93z's Avatar
A couple of questions first though. How easy is it to convert back to electrical type gauge. Also how do you install a mechanical. I looked at my capillary tube and at the end of it the tube was pinched close. How do i open it? or do i use a capillary tube that comes with the mehcanical gauge?
Old Aug 29, 2007 | 04:40 PM
The93z's Avatar
bump.
Old Aug 29, 2007 | 05:52 PM
Just unscrew the mechanical sending unit and re-install an electrical one and run your wire from the sending unit to the gauge.
