Battery/Alternator Question
After replacing both the meter read 13. Normal right, then by the end of the night it starting going down again. I barely made it home, battery wasn't even reading, no lights, just running off motor. Battery can be charged but just dies again. Think its a bad alternator or something to do with the connection between the two??
Yea, listen to the man. I went through seven, count them SEVEN in a year because I figured I'd come out ahead and if it went out, I only pay for labor. WRONG! I was finally convinced to go with a HI LO one and havent had any problems in about 5 months now.
i bought the re-manufactured one from Autozone.. it has a lifetime guarantee. so if by any chance it craps out on me again, i can just take it out and replace it for free
haha yeah.. it was a hassle the 2nd time around.. i feel like a pro @ changing alternators now.. i dont know if thats a good thing or bad thing
i feel the same way.. but SOB, mine just went out again!!
ive noticed that the past 2 times its blown its happened right after ive rev'd it up high and hard... anyone know any other cause of this? do autozone's alternators really cant handle it????
ive noticed that the past 2 times its blown its happened right after ive rev'd it up high and hard... anyone know any other cause of this? do autozone's alternators really cant handle it????http://cgi.ebay.com/ebaymotors/ws/eB...m=130099219015
It cost me around $300 for the alt, 4 gauge cable and the three day shipping. It's a hefty price tag, but I'd rather be rid of this problem once and for all and also the 100amps is a nice extra. Will be installing it myself tomorrow (while I'm in there I'll also change the belt), until then I'll be reading a lot of threads in this place since I'm rather nervous about doing this since I'm no mechanic.
Their alts are bigger than the stuck so if you have a performance pulley you might have some problems with it and it only uses two of the three mounting bolts.
If you have anymore questions regarding their alts, I suggest you ask this guy since most of the stuff I read was posted by him.
https://ls1tech.com/forums/member.php?userid=26713
BTW got any advice for a first timer?
Do you use a tq wrench or do you go by feel?
some tips--
of course the usual..
-disconnect the battery
-take off the airbox and the 2 electrical plugs. u wont be able to remove and put the belt back with the airbox in the way
-cover your throttle body and (stock?) air filter so no dirt gets in/on it.
-u will need a 13mm ratcheting wrench for the rear screw of the alternator... it was damn hard to reach it with a regular ratchet and socket.
-trying removing the alternator first w/out the bracket.. it will be 1 less screw u will have to remove and put back. u might have to wiggle it around to get it out but i will be less time consuming when doing so. and yes, i just went by feel.. i should use my pop's tq wrench, but i rarely use it
good luck, let me know if u have any other questions
Yeah it's probably a better idea to get the 160amp one (depending on it's price), I couldn't find a lower one than 200amps on their eBay page so I went with that one. Probably should of checked with them on their home page, but I was in a hurry to get it fixed.
http://superpageshosting.com/4alters...8&catuid=10155
some tips--
Will do, thanks for the advice
