Sponsored by: CARiD
squealing at full lock
Old Aug 27, 2007 | 11:27 AM
devin.flohr@us.army.'s Avatar
Default squealing at full lock
When turning at low speed with the wheel at full lock there is a low squealing or howling sound coming from the front of the car. The car is all stock so idk any ideas?
Old Aug 27, 2007 | 02:47 PM
shaun's Avatar
both my cars do that and also some other ones i have owned. my 04 escalade did that when i got it and i added some of the lucas stearing stuff and it went away and also the same deal with me z. just buy some lucas and it will go away.
Old Aug 27, 2007 | 03:33 PM
derekderek's Avatar
It's normal any car you drive when you turn the wheel full left/right the power steering pump is going to whine alittle bit. I would'nt worrie to much about it.
Derek
Old Aug 29, 2007 | 03:21 AM
waldershrek's Avatar
Is it more of a whine or a squeal?
whine = normal
squeal = not normal
check the fluid just to be safe and add some Lucas PS additive
Old Aug 29, 2007 | 05:36 AM
Roadhouse's Avatar
It's not good practice to hold at full lock, puts alot of strain on the pump and lines.
Old Aug 29, 2007 | 06:31 AM
That's true also especially if you fluid is low
Old Aug 29, 2007 | 07:39 PM
sdm1234's Avatar
check tire pressures as well. one of them may be only sqeueeling during sharp cornering.
Old Aug 29, 2007 | 08:03 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
miles on it? have you checked the wheel bearings?
