Sponsored by: CARiD
EVAP system
Old Aug 27, 2007 | 07:44 PM
94 redbird's Avatar
Default EVAP system
can someone explain to me what this is and what it does? also would it be bad if a car is throwing a code for it? what would be wrong with it to have that code?
Old Aug 27, 2007 | 08:27 PM
2001BlkWS6's Avatar
Had the same problem. More people could probably help if u had the number of the code like P0442 or at least thats what mine was.
Anyways its a vacuum system. I ended up having my tank smoked and there was a leak above the gas tank. Best bet and quickest find is to have a dealership smoke it for you. Around $60.00
Old Aug 27, 2007 | 08:45 PM
94 redbird's Avatar
then after you get it smoked and they find the leak, how much is it to get it repaired?
Old Aug 27, 2007 | 09:09 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Moving to General Maintenance & Repairs....
Old Aug 27, 2007 | 11:10 PM
ghardester's Avatar
I used to get the EVAp error code in my V-6. Loose gas cap due to not being put on right. Can't pump my own gas here in Oregon. So I got a scan tool to turn the light off and started watching the fuel attendant more closely. It is just a leak and should not affect the performance of the car. Could be as simple as needing a new gas cap.
