fucking headlight motor
Old 09-03-2007, 01:24 PM
rumblebox's Avatar
Default ******* headlight motor
my left side headlamp motor gear is stripped and makes a Godaweful noise when it goes down for about 6 seconds. do i need to change the whole motor assembly or just the gear??
Old 09-03-2007, 01:50 PM
Josh McGrath's Avatar
Personally, I would buy the brass gear on ebay. But you can just take the gear out and turn it over and use the non-stripped side.
Old 09-03-2007, 08:32 PM
chrysler kid's Avatar
yeah i was going to say the brass gear set usually does the trick. do an advanced search and youll get the answers you need
Old 09-03-2007, 09:10 PM
hardcorebob's Avatar
http://www.bfranker.badz28.com/headl...tm#MetalGuide2
Old 09-03-2007, 09:22 PM
Moderator
BizZzatch350's Avatar
Do the brass gear, easy swap and solves the problem
