help with my metal screeching/ squeaking sound
hey all, i have just recently developed 2 small problems with the car, and i am trying to diagnose it.
on a cold start, when turning the key and cranking it over, there is a metal screeching sound that happens right before the car fires up. the car runs just fine right now btw, but these noises are just bugging the **** out of me!!
so after it fires up, then there is a light squeaking, like a pulley sweak that goes with the idle of the car. any ideas of what's happening? after i warm it up for like 10 mins, and then drive a good distance (3-7 miles), the squeaking will disappear. if the car sits for more than an hour, and i fire it up again, the squeaking comes back, anything less than an hour still no squeaks.
so a recap, metal screeching on cold starts only, and a squeaking pulley?
here is a vid when the noises started happening. i was just shooting a vid of a walkaround at the time so i didnt focus on the noises, but you can hear them!
http://s145.photobucket.com/albums/r...t=pict0006.flv
it almost sounds like i have a procharger!
anyways... any help is appreciated!
1 Post
on startup, maybe the starter is too tight (needs a shim), resulting in a screeching noise.
as for the squeek, when u rev it up slightly, does the squeek change pitch with the engine speed, or stay constant, or even go away?
yes, the squeeking does change pitch with reving.. when normal driving it for awhile, the squeak will go away. i have already had to change the idler pulley, so that is out.
as for the starter being too tight, i'll look into that. i just put in a tci flexplate and swapped out my tranny so that could be a possibility. isnt the flexplate connected to the starter?
thanks guys for the input!
There is also the tensioner pulley, have you checked that one?
If a pulley is hanging up anywhere (tensioner, power steering, water pump, AC) so that it doesn't turn right away or it won't spin at full speed right at first at startup it can cause a screech because the belt slips on it. Once the pulley is turning it can squeak for awhile then go away (depending on how bad it is). I've heard this before.
After your car has been sitting for long enough for it to do it, try having someone (or maybe two people) watch the engine when you start it up to see if anyone can spot a pulley that doesn't spin right away or slower than it should at first.
Just throwing out ideas as they come to my head. Hopefully you get it figured out soon.
ttt... well an update now.
i got rid of the squeak by replacing the belts with gatorbacks.... but i still have the screeching at cold startups. i will post up a vid of a cold startup tomorrow... but any ideas from anyone?
