Gas mileage disappeared
If your PCM, for whatever reason, goes into a Speed Density tune you will burn alot more gas, ALOT. And you will get no codes that this has happened and the car will run PERFECTLY fine.
The way to see if you're in SD tune.....start the engine, while its idling, unplug the MAF and rev it up by the TB arm. If it runs normal you're in SD tune. Also, you can unplug the Throttle Position sensor too, and the engine will run normal without it if you're in SD tune.
My car right now, is in SD tune, did it on its own long ago....have no idea why...but my car/engine runs PERFECTLY. My gas mileage did get worse though.
So, no, after 4 years they should be just fine unless you have some other problem that is damaging them.
Bad 02's will cause your engine to run like HELL, backfires, spitting, stalling, rich, missing....you will know something is really wrong.
A code will not always show from bad 02's, also a scan will not always show a bad 02, but an OBDII scanner will show you if they are working and switching properly.
