Sponsored by: CARiD
clutch chattering
Old Oct 5, 2007 | 10:33 PM
micah's Avatar
Unhappy clutch chattering
i just put in a prothane tranny mount after i had ripped the stock rubber one in half. i also put in a torque arm bushing while i was in there. after i did this and drove it around i noticed that my clutch was making alot more noise when it is engaged. is this normal when you stiffen up this area? or have i damaged something in the clutch when it was loose. the clutch is a ram. i think it was the HDX, not positive. any ideas?
Old Oct 5, 2007 | 10:36 PM
brad8266's Avatar
The noise could have just been covered up before. Does it make the noise when the pedal is pushed in?
Old Oct 5, 2007 | 10:45 PM
micah's Avatar
no it just makes the noise when it is engaged
Old Oct 5, 2007 | 11:20 PM
brad8266's Avatar
Very possible it is a bad pilot bearing.
Old Oct 5, 2007 | 11:49 PM
micah's Avatar
i hope not but i guess im just ganna have to rip it apart and see. thanks for the info
Old Oct 7, 2007 | 03:32 PM
proelky's Avatar
Depending on your clutch, it could just be a little chatter. Mine does the same thing on take off under low throttle. Never happened when it was stock, but started after a new tranny/textralia z clutch was installed.
Old Oct 7, 2007 | 05:21 PM
micah's Avatar
does it chatter when it is in neutral?
